"Shared" section in Finder
18 Oct 2002
Southampton
Hi, I'm new to macs, but i think I'm already converted. I do however, have a question.
My home network is mainly made up of Vista machines all shared under one workgroup called "Workgroup". I have set my MBP to be on that workgroup too.
Are all the PCs meant to show automatically under the shared section? as nothing is there unless i manually connect to a network share using apple-K.
If they are meant to show up, how can I make them do so?
thanks
Be ready for them to disappear and reappear randomly. I've had this problem since installing Leopard, and it's very odd. There's a huge thread on the apple support forums about it, but no definitive answer.
yeah, i have noticed that too. Not a huge problem as i can still manually connect. just a problem if i wanted to add a printer. so i guess its a case of add the printer the first time you see it.
edit: you got a link for that? might have a look.
Can't actually find the thread I was talking about, it seems to have mysteriously disappeared from apple's forums, but whilst I was looking I found this thread giving info on getting Leopard to play nice with Windows shares. Might be worth a look.
