So guys i have just moved into a new flat which has a wifi connection for each flat. The building is built to modern standards with thick walls but i get up to 50 mbps.
Now the thing is that i cannot get a wired connection from the main router to my flat because (a) i cannot find the router lol and (b) im not allowed to drill a hole for a long ethernet cable.
Another thing i have noticed is that there are a lot of different connections in the building. Im assuming that my connection is also being shared or is interfered with other connections that is dropping my connection during online gaming.
So im hoping if you can advise me on the best option i have in terms of improving the wifi connection in my flat.
Is there such a device which i can plug in my flat which will improve/boost the incoming wifi signal and allow me to connect an ethernet cable to it for my game machines?
Thanks.
Thanks.
