Sharing access point
18 Jan 2007
Dorset
I presently have my PS3 connected to the net through a power line kit linked to my router. Is it possible to split/share the connection at the PS3 end with another device? Neither device would be on at the same time.
Or do I just need to remove the ethernet cable and swap it over each time?
Many thanks in advance!
You could swap the cable over if you can do the hassle. You could alternatively buy a switch and have them both connected. Your choice.
