Sharing files over wifi network
15 Mar 2006
Vancouver, BC
I need to know how to share files between my 2 PC's that are both on the same network. My setup is 1 pc with Vista Home Premium and 1 pc (media centre) with XP Pro, neither PC is hardwired into the Router. The router is plugged into the cable internet connection directly and then the 2 pc's are connected via WiFi. I have a D Link DI 524 Router, D Link G122 USB on the Vista PC and a D Link WUA 1340 USB on the Media centre.
I believe its just the same as if they were wired together; enable file and printer sharing, configure firewall so that each pc can see each other (firewalls like ZA make the PC hidden on a network etc), make the appropiate share permission on the folder you want to be shared.. Then start->run and \\computername.
Ive probably missed something, but thats the jist of it.
Unfortunately this is not working, even if I turn off both of my windows firewalls I still cannot detect the other pc or connect using the Run method.
Can you ping each PC from the other?
Are they in the same workgroup?
Do you have an ID & password that's the same on both PCs?
Not sure if I can ping them, but they are both in the same workgroup i believe.
I tried the wizard last night but it needs a floppy disk to save the settings for the other pc, I have no floppy drive.
Dont worry about saving the settings for the other pc on the floppy disk, just use the option 'Just finish the wizard, i dont need to run the wizard on the other computers', restart if promped to then do start->run and \\computername.
Hopefully that should work, it did for me.
Yes run the network wizard on both... ive had a few problems where ive enabled file and printer sharing through network connections and they still didnt see each other.. then i did it on the network setup wizard and it worked fine.
Ok so I need to run the network setup wizard on both machines. In XP do I select the wifi wizrd or soho wizard? In Vista they give you lots of options for a network so not sure which one I need there. I have tried the \\computername but they will not see each other, even when I turn the firewalls off.
Ok so I tried the XP setup wizard and it asked for a USB flash drive which I had, and it save the settings to it and then asked me to insert the flash drive into my Router, it has no USB port :(
I guess I could choose the manual option and see if that works but there is no printer on the XP pc atm.
