I would feel quite awkward having an eastern european guy shaving me in the shower, I dunno about you lot.yhack said:If you're that rich then pay someone else to do it![]()
pitchfork said:I would feel quite awkward having an eastern european guy shaving me in the shower, I dunno about you lot.![]()
BUSH said:The best products i've found for razor burn/rash are:
Tend skin solution ~£10 - This stuff is seriously strong, and will help with razor burn and ingrown hairs immensly but you'll need to use an aftershave balm afterwards as its very drying on your skin and it stings like aftershave when you put it on your skin. I only use it for the occasional bad patch of razor burn, and if your skin is already dry I'd be cautious about using it.
And I was the oppositehyper_piper45 said:I used to get razor burn no matter what products i used, technique etc etc.
I decided to change to an electric razor and i have have not had a problem since.
Tru said:Shaving in the shower beats all. Use a half decent razor, doesn't need to have batteries or 17 blades.
