I've not come to a decision yet on securing the slabs to the base, there are a number of options though like pins that hook onto the plastic grid panels underneath. The grids are all filled in with pea gravel for added rigidity. Pins would stop the slabs from moving but tbh the weight of them combined with the weight of the metal shed, it's unlikely they are moving anywhere really I guess.
I think a good option will be to secure the outer slabs to the base with pins and the inners are left in-place as the shed will be covering those anyway. Then once the shed walls are up, secure the walls to the slabs from the outside using L brackets or hook pins. I did plan on sealing around the edges once all that is done to stop water ingress as well and then I can just floor liner the interior and call it a day.
