Sheet Aluminium to match Lian Li
17 Dec 2004
Crawley, WEST SUSSEX
Hi,
Just wondering if anyone could point me in the right direction to get some Aluminium sheeting to match the Silver Lian Li finish. Want a piece the size of 2 x 5.25 bays. Prefreably in Surrey so I can go have a look at it to make sure it matches the Lian Li.
Thanks
Argh i couldn't take a jiggly saw to a Lian li side panel, unless i was making a side window. Hmm if you want to make a side window you could kill 2 birds with 1 stone.
Mark
other suggestion is to make a side window if you haven't got one and use the cut out bit, that's where my piece is from :)
If you purchased a sheet of aluminium it would need to be brushed or you would need to be able to do the brushed effect yourself.
You can always try contacting Lian Li directly via email.
Giving details of where a side panel could be purchased would be a competitor. They are not widely available but depends on what panel you want.
I have a couple from cases when I replaced the panels with windows, if you drop me an email about it I may be able to help.
AFK_Matrix said:
Hi,
Thanks
What it going to be for? If it's for an LCD type use IE with some kind of hole then you can get double bay plates
Hi Harib0,
No its not for a LCD. I basically wanted to get an Aquatube Reservoir for my Watercooling but have been told to avoid aluminium like the plague lol. So the Aquatube is out, but I really like there bay mounting with the hole so you can see the Aquatube, and it could also have a light there. So want to basically create my own by getting a dual bay Dangerden res and then make up a front for it similar to an Aquatube. Thus a 2 bay piece of aluminium with a whole in it, some plexi glas and some nice bolts & LEDs etc. Will get in contact with you about the dual bay plates as there not on lian li's website??
Humm thats intresting why avoid alu??
Not being funny buy this is godlike:
And if you have a valid reason for not haveing alu then i think i have the solution my friend ;)
These tubes are in short supply but there is one UK company i know of that will have some soon - can't metion names for the rules tho ;)
