Sheets of dust filter???
1 Mar 2024
Leeds
I just grabbed a lian li a3 and I’m wanting to fully dust filer the vented side panel can you buy large sheets of the stuff?
I bought this stuff recently for a very similar project.... it it just a roll of fabric, though.
Edit - and being speaker grill cloth its pretty thin, if that's a consideration.
the truth is my A3 side panel is vented but very open, and i can see all the crap inside hahah, also you get a lot of component noise like when you move the moue and stuff like that.
PSU fan as zero DB setting, cooler is a NH D15 with fan fixed at 400RPM and fans are P12 silent at 50%, but as with everything it still give's of some noise and with the panel been so vented i can hear it.
i know fro xperance that adding a fan filter can block a lot of noise as it reduces the open space, so that's my plan
Yeah a slightly thicker material will help damp a bit of noise, if that's your goal -speaker cloth will stop dust but is designed to be 'acoustically transparent' so doesn't block noise, just dust.
yer thats the plan, the other option is a glass panel as i know that blocks a lot of noise but the system is a real mis match of parts and i dont want to enter that money pit
I bought a roll of dust filter off ali express but made the mistake of not buying magnetic strips so im waiting for that to come. I wanted make a filter for the back of my nr200 as ive got my cpu fan intaking from the back.
You could contact demcflex and get them to make a custom grill for you, I use them on my phantek nv9.
