shell script ...
9 Dec 2004
Dorset
Hey all :)
I have a very very simply shell script running the zebra and ospfd daemons. As some may know - if you run these from the commandline they debug output onto the terminal.
Is there any way that I can make my script open a terminal and run the command from within?
i.e;
zebra -f /etc/quagga/zebra.conf
ospfd -f /etc/quagga/ospfd.conf
and in pseudo;
zebra -f /etc/quagga/zebra.conf | display in new xterm
ospfd -f /etc/quagga/ospfd.conf | display in new xterm
Thanks for any suggestions...
I'm no expert, but wouldn't:
xterm -e zebra -f /etc/quagga/zebra.conf
xterm -e ospfd -f /etc/quagga/ospfd.conf
work? You will have to use two separate scripts, one for each command as the second will always wait for the first to finish executing.
