Shelving systems like Ivar
1 Jul 2007
We have a cupboard looking to shelf out using something like the Ivar range from ikea.
The cupboard itself is not the deepest and has various pipes running through it, what other systems are out there as options to look at?
Looked at one custom range and I think it came in at £240odd.
They look pretty plain, can't you make the shelves yourself ?
I'd go with this. Make some slatted shelves, you can make them exactly the right size. you only need 3 battens of 25mm pine on each side of the cupboard then more of the same wood equally spaced to make up the self, would certainly cost a lot less than £200
