- 18 Mar 2012
- Eastbourne
I've decided against my idea of a watercooled ITX build and am going to watercool my current build with a full loop this time and hardline tubing this time round mainly because it's quite noisy at the moment, my H105 is dying and I can't get hold of original owner to RMA and it looks pretty!
Spec is in my sig.
I can fit two 360mm Rads but i'm thinking 280 + 360 will be plenty even if i do decide to pop another GPU in? Or would you go 360 just because it can be done and saving me do it later?
I'm going to be buying new, well most of it anyway! So what do you think of this proposed loop so far.. ?
YOUR BASKET
1 x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump) £107.99
1 x EK Water Blocks EK-FC Titan X - Acetal+Nickel £89.99
1 x EK Water Blocks EK-Supremacy EVO - Nickel £52.99
2 x EK Water Blocks EK-CoolStream PE 360 (Triple) £49.99 (£99.98)
1 x EK Water Blocks EK-FC Titan X Backplate - Black £22.99
1 x Mayhems Pastel - Ice White Coolant 1L £14.99
Total : £388.93 (includes shipping : Ex.VAT).
I'm unsure whether to go for PETG tubing or acrylic?
What the pro's and cons of each? I was reading through the project logs and seeing that PETG is a bit harder as it doesn't hold it's shape as well?
And tubing i'm guessing 12/16 is the normal? So would the 12mm Bitspower fittings be okay with that?
YOUR BASKET
1 x Bitspower Connection 1/4 Inch to 16 / 11mm - Carbon Black £11.99
1 x Bitspower Crystal Link Tube 1210mm, Length 1000mm - Clear £5.99
Total : £17.98 (includes shipping : Ex.VAT).
Also, a basic 6 channel fan controller that I can hide away. I've had one of them aquero things before and didn't understand it and it annoyed me so not one of those please! They all seem to be DVD drive ones?
A PSU that doesn't have y split PCI-e cables like my antec? So then i can send the cables to Pexon to get them done properly. Preferably about 1000w for future SLi
One of these would be suitable? Not bothered about the lights as it'll be hidden.
YOUR BASKET
1 x SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black £184.99
Total : £184.99 (includes shipping : Ex.VAT).
I've got 4 sp120's which i could use but would like to change them out for another fan and get a matching set, i don't really understand fans so hit me!
I don't think i've missed anything. So what do you think of that?
Spec is in my sig.
YOUR BASKET
YOUR BASKET
YOUR BASKET
