Shielding front panel audio - any ideas?
29 Sep 2014
Hi Guys,
Every time I use the front audio panel on my NZXT h400 I get static noise when gaming (on desktop only is fine), is there any trick to shield the cable at all?
I assume is the cable as it runs by the 1080ti and my Asus Strix z370 Mini has the connector near, well quite a lot of MB have it close to the PCI slot.
No issue whatsoever from the back of the mobo, I was just wondering if there is any successful idea to shield it else will just get an extension for the 3.5" jack to connect my headset.
Thanks!
Never used front panel audio is my advice, always use the back and preferably, a USB DAC. Get an extension for your headphones.
i have never used it on my computer in fact its not even plugged in ha ha jsut plug into the back
front panel cabels usually arent shielded properly for audio signals
theres a lot of stuff going on inside your pc tyo create interference
