Shift light...
Caporegime
1 Nov 2003
Lisbon, Portugal
These seem a bit gimmicky to me?
I would have thought you should be able to tell from engine noise and response, you've also got a new exhaust fitted recently iirc which should help.
Yes, I know my car peaks at 6750rpm - It's mainly for internet points and the fact I feel like having one :)
Dorje - that's my view too, you can tell by engine/exhaust note when you're too high in the rev range and so need to change up.
I personally don't see the point in them, especially on an everyday car.
Either way, I'd still like one. :)
My mate had one. Saying that, he had a supercharged Civic Type R, which entered VTEC earlier than a standard car and rev'd about 1k rpm higher, so it was quite a nice addition.
I think if his was standard, he'd have looked like bit of a douche.
Been thinking about fitting a shift light to my car, will be handy for track days, Santa Pod and when I'm doing TLGP in local towns in Essex.
Nothing useful to add to this thread but that's a cracking line :D
Get an Autometer rev counter with a shift lamp for the win :D
They have removable rubber shields (various colours) so you can dim them for street use, very bright without - ideal for that split-second warning when you've got the hammer down :)
More precise readouts than the OEM gauges as well...
You can add ancillary lights as well like oil pressure warning lamps, high temp, etc :)
I like that Lewis, but its a bit over the top. If I was making a proper track/drag car then yes :) - Just want something simple for now.
What are your soldering skills like? If it was me, I'd just make the circuit myself. The parts for it would probabaly be under £5, it'd just be a frequency to voltage converter, and an op amp connected as a comparator, an LED for the output and a few resistors & a potentiometer. Also a bit of veroboard or similar to solder on to.
Haha :D Been around since 1957, Autometer, mind! Always been the mainstay gauges of most American muscle cars and racers before 'that' scene got hold of them :)
Only proper cars should be allowed autometers :p
That's a good example :D
