Worth trying the uberbike pads, but I had very little joy/luck with the race compound hardly seeing 2000 miles before needing to replace them. Noisy too.
I've just put a set of these on, they look very similar to the pads which came with my RS685's which I got nearly 5000 miles out of, so hopefully the same!
anyone know where I can get a pair of screws that fix the pads to the caliper? I got a pair of 2nd hand caliper's and they didnt come with the screws which was ****.
I previously bought these from wiggle to replace one that I knackered the head on. They're longer and hex (rather than slot headed) but thread the same and perfect swap out. They're OOS now but you can get them various other places.
There was a discussoin about them in the main thread a few weeks back and I linked a load then, look back through from posts from me (I've not got time otherwise I'd grab it for you). Think I even found a black one!
