Shipping Curved Monitor
26 Oct 2003
My G7 27-inch curved monitor got damaged and I don't want to lose it. So I guess I have to look for the best way to protect it or to pack it carefully. It will be shipped as a manila envelope so it cannot be damaged. However, I can't find a similar box. Any advice would be greatly appreciated!
say what......you want to ship it in a manila envelope, not sure that will prevent it being damaged! :p
if you need a box i'd suggest popping into a supermarket and asking them for a large box then cut it down to size and pad out (not with a manila envelope!) as necessary.
If you don't have the retail box I'd probably wrap the monitor in a layer of bubble wrap, then a layer of cardboard and then in a larger box with packing.
"It will be shipped as a manila envelope so it cannot be damaged" ...I've re-read this half a dozen times now and I just don't know what you are trying to say here. In anycase, you'll need a solid box and preferably some polystyrene to be cut to fit and support the curve, safely posting a curved monitor without the original box or the box for another monitor you can make fit is going to be risky.
Sorry nmy initial post didnt make sense.
I meant I will be wrapping it in manila paper (I think thats what its called) and marking it as fragile but I need to try find a box to wrap it and put it in.
I will try the local supermarket thank you, I was hoping there may of been something better for the job.
Thank you
there is, the original box and the polystyrene inserts it came with :p you don't have those so will have to improvise. also, a manila envelope is just a padded envelope. you want bubble wrap or similar to protect the monitor.
