Shipping PC advice
11 Dec 2013
i have an OG mountain mods case (horizon, the horizontal mobo layout) with 360mm rad on the front. i'll be shipping it to oz in a container (along with the rest of our stuff), it will be individually crated. any advice on prep? i'm reluctant to dismantle it as i'm not convinced it will be much more secure that way, except for a couple of obvious things.
  • GPU is a 5090 FE, will definitely remove that and pack it in its own original box.
  • Will disconnect and close off CPU block (probably just u-turn a hose)
  • Will d/c and close off rad (as above).
  • Will remove reservoir and pump entirely (glass aquacomputer pump/res combo), it's heavy and in-use is secured with velcro strapping.
  • Will remove PSU as it's big and heavy unit.
was thinking i would leave everything else in-situ (including HDDs etc). is there anti-static bubble-wrap i can stuff the case with to provide a little more cushioning in case things do move around? the only thing i'm not entirely sure of is the radiator, it is secured by 12 screws to the case, i could additionally velcro-strap it as backup for shipping.
You can actually buy an expanding type of packaging for the inside of your PC, it fills the empty space to stop things from moving around/getting damaged as easily.
Some of the pre-build companies use them for shipping PC's.
I don't know how good this particular brand is, could be worth looking into it a bit more.
Regardless, I'd still ship the 5090 in its own box.
OCUK don't sell the above so I assume I'm safe to link it.
I think that's stuff Gamers Nexus gets excited about when they see it in prebuilts.
If you pull the GPU and reservoir, it should keep everything in place.
Are you taking the 5090 in your hand luggage?
I believe so, not sure if there's a difference between the companies that supply it or not but it's good stuff.
Funnily enough looking at the reviews on the page, there was a bloke who used it to ship his gaming rig from the UK to the USA.
I know it's not the same (by far), but when I moved about 125 miles to my new house I decided to just drain the coolant and pack the inside with towels and bubble-wrap. I didn't remove the GPU but I laid the case on its back in the car so that the GPU stayed vertical.
