Got this off the MKIV Supra Owner's Forum www.mkivsupra.net
One of the members went to Turbofit to have a full engine rebuild, manual conversion and some general smartening up of the engine bay and these were the results which i just had to share
This is a copy of the email that he sent to Turbofit after the works were carried out...
In Feb my car arrived with you for an engine rebuild, manual conversion and some general smartening up of the engine bay.
The last time it came in to you to have the oil leak sorted I asked for a FULL MECHANICAL CHECK OVER. It has therefore come as a great shock to me to find the following errors listed by TDI who I had asked to carry out a thorough check.
Gear lever insecure - wobbles
Lower gear lever bush is missing
Gear lever itself is secured with a brass wood screw :?
Turbo intake pipe has poor quality welding and a restrictive bend in the centre
Braided breather hose is pinched closed, poorly secured and rubbing on other pipes/wiring/clutch master cylinder
HKS SQV points directly at air filter and will be blowing oil mist over the intake
Several boost/vacuum hoses are loose or blanked off and lying/dangling around the engine bay
Inlet manifold top retaining bracket is missing, meaning that the manifold is not supported by the cylinder head.
Fan shroud is cracked and broken
Rear coolant to heater pipe is poorly secured
Braided fuel hoses from fuel regulator to fuel rail is chaffing on other pipes and wiring
Turbo oil feed is rubbing on oil return pipe work.
Apexi boost solenoid is loose
Coolant over flow tank is a 'red bull can'. :shock:
ECU wiring is connected with multiple bullet connectors
Battery is located and secured with several 'zip ties'. - done by me, as was held down by nothing.
Slave cylinder pipe is poorly bent to fit.
Both gearbox clutch inspection plates are missing, allowing foreign objects to easily get into the bell housing.
Gear lever lower brace bushes are extremely worn - 4-6mm of play.
Fuel filter and fuel lines are poorly secured with 'zip ties' from engine bay to tank.
Serious oil leak appears to be coming from the rear main seal.
Restrictive flow due to welding on the turbo intake scroll.
Waste gate screamer pipe is fixed with only 2 out of 4 bolts.
O/S/F tie rod and sub frame brace are both missing.
Lower inlet manifold support bolt is missing.
Lower section of quick shift is broken.
Paint on the engine appears to have been applied with the engine in situ. Unusual if the engine has been removed for a rebuild?
Appears to have the incorrect oil in the gearbox - current oil smells very burnt.
Gearbox oil is very low.
When I picked up my car there were a few light scratches on the vehicle that had not been there previously.
However there was also:
Damage to the bonnet on the top corners where it was left on the floor. There is now no paint on the corners and there is a 3 inch scratch in the middle of the bonnet.
There were also two major chips behind to o/s door, on the actual quarter panel and there are some drips of primer on the n/s/r quarter.
Over all, after paying in excess of £6500, excluding parts, I do not feel I have received anything like the quality of work I have paid for.
I would like you to respond to this and let me know how you intend compensating me.
I have given you more than a fair chance to put things right on the car but having now lost faith in your level of competence will not be bringing the car back to you.
Please see the photographs I have attached.
