- 26 Apr 2004
- Milton Keynes
Ok, ok, shoestring budget might not cover everything as simply as it could, but to try and keep this as simple as possible:
I have some nice floorstander front speakers in my AV setup, unfortunately I had to sell my prized subwoofer when I moved house and got married to free up collateral
A while back, I was given (yes given) a Pioneer SSLW500 PASSIVE subwoofer (rated up to 100w, not sure on sensitivity unfortunately), my amp is good, but it does not have active output as far as I am aware. In the future, I would like to get another decent active subwoofer, but for now, I am trying to make do, and would like to get a little bit more bass/bass depth into my setup.
I have an old Ariston stereo amp sitting at my parents which I believe is 30w per channel 8ohm, I'm going to guess the sub is 4ohm, and generally given I have seen 40wpc 6ohm for the Ariston, I'd take a wild guess it'd translate to about 50wpc 4ohm, so 2x 50w =100w, perfect(?). If I was to split the mono subwoofer output from my amp's subwoofer pre-out, and feed it into both Aux channels on the Ariston, could I use this as a makeshift subwoofer amp?
My subwoofer will deal with the filtering/frequency cutoff before passing to the pre-out, so essentially all my amp will be doing is amping the low frequency level my amp passes.
My mind is telling me there is no logical reason this shouldn't work, but I don't fancy spending money on the cables/splitters etc and waste my time messing around with it if A) It won't work B) It won't make any real improvement C) It'll just kill the amp.
What are your thoughts?
