shogun 2 crashing after update, any help guys?
233
233
21 Nov 2004
Wishaw
hey guys have shogun 2 installed via steam
auto updated and hey presto it hangs on the start up screen resulting in an alt-tab to get out and a shogun 2 has stopped working message :(
now the thing is no other programs are having problems running and i haven't changed anything in my rig
anyone able to help out a fellow ocuker in his hour of need?
any advice appreciated
rig spec (not that it makes much difference i'd imagine
q9450 @3.4ghz
8 gig xms2 ram
p35 ds3r
6970 running 11.5a
any thoughts please guys?
yup tried verifying, reinstalling disabling sound cards, disabling av and firewall
and still the same crash :(
just incase anyone searches and has the same problem :)
sorted with this bit of advice of the TW forums
Did you,or have you any Mods installed ? If so,take them out,delete the scripts and fx_cache files from the Appdata/Roaming/The Creative Assembly/scripts and Appdata/Roaming/The Creative Assembly/Shogun2/fx_cache folders,verify gamecache and try again
