I actually had a look at my website/pictures on a different laptop (Sony Vaio) and HD LCD TV connected through HDMI, and I think I need to give my monitor a calibrate, since it looks vastly different on those monitors and LCD, but on another laptop (Asus) it looked fine and on a Samsung LCD HDTV it looked fine too. iMacs looks the same as it does on my screen (MBP) so Im currently looking into the Gretag Eye-One i1 calibrator. Any chance anyone used this before, is it any good?
Cheers![]()
They look washed out to me but I don't know owt anyway.
but saying that it a look i'm a fan of.I'm viewing them on a 24" iMac and they just dont look right.
Very simply putbut saying that it a look i'm a fan of.
Hmm, definitely going to look into a calibrator then. Thanks for letting me know, since I never really get to see/use other computers besides looking at my own when working.![]()
I get it lots when friends view my photo's on there machines and then they see them on my iMac they cant believe the difference.
Nice shots. I also like a washed out look, but I just don't think it has been applied very well here. It looks less washed out and more over exposed to me.
I'm not a fan of high-keying so I may be biased here, but I think they've been pushed too far and end up pretty dull.
Compositionally, there are some problems as well I think.
In # 1 the girl is looking the wrong way, she need to look into the space of the photo not outside the frame.
# 2 subject too small and appears to be sleeping, combined with the lack of detail form the high-keying make the photo dull.
#3 is a better version of the same theme. My problem is her face, hat, hair, cardigan sleeves are washed out and lack detail, but the stone texture on the bottom and sides have a much higher contrast and thats what draws my eye. the best of the 3 for me though.
#2 shes looking out the frame...I actually had a look at my website/pictures on a different laptop (Sony Vaio) and HD LCD TV connected through HDMI, and I think I need to give my monitor a calibrate, since it looks vastly different on those monitors and LCD, but on another laptop (Asus) it looked fine and on a Samsung LCD HDTV it looked fine too. iMacs looks the same as it does on my screen (MBP) so Im currently looking into the Gretag Eye-One i1 calibrator. Any chance anyone used this before, is it any good?
Cheers![]()
Calibration isn't something to get your monitor matching all your various output devices.. It's something to use to be relatively sure you're seeing the correct colour and tonal information in the file (screen specs permitting). It's giving you a starting point you know is right. You can't possibly create a file for every different type of screen your photographs will be seen on so don't bother trying. Just make the file and know it's right, and if anyone else is viewing it on a calibrated screen hopefully they're seeing close to what you are.
Edit: For referance, I'm looking at these on a very accurate monitor, and I think there fine. Though I prefer the more 'flat' look of number 2 and 4, if anything I would be going for less contrast, not more.
Second Edit: Infact the difference between 3 and 4 is night and day. 3 looks like you've just found the overlay blending mode, 4 looks to have a genuinely nice tonal range and feel. Looks far more professional IMO.
#2 is a fantastic image. I agree with the comments above about the set being a little overexposed though.
Im not good enough with photoshop but ideally I would select just her (very hard due to hair etc) and make the background slightly desaturated, making the main image (her) pop out.
Looks slightly better with black background :
http://www.fluidr.com/photos/forty-forty
I love the look personally, maybe a touch overdone. My work monitor is normally quite dark so when I check at home later I'm sure they might be a bit too washed out.
I think a bit of noise would set these off. I know people seem to run away from noise I but I love the 60s/70s feel to the pics.
