Hi all,
New to photography but i'm from a technical background so i think i'm picking up the terminology and ideas quite quickly.
I got a new lens this weekend, Sigma 10-20mm f4-5.6 EX DC HSM, and thought i'd test it out indoors along with my walkabout lens (Canon EF-S 18-135 mm f/3.5-5.6 IS Lens) at an 'early xmas' party.
I struggled with the light being really low, but i didnt want to turn flash on as A) its irritating and B) it will flatten the photo.
I used my walkabout lens on ISO 800, lowest f-stop possible (to let the most light in) and a slow-ish shutter speed - about 1/30 - 1/40 as i was hand holding the camera. The shots all came out rather dark, and I had to get them to a half-decent standard by editing in Photoshop/Lightroom as I was shooting in raw.
Belows an example picture:
As shot
ISO 800, 42mm, f/ 4.5, 1/40 sec.
After edit
Edited in lightroom.
From my understanding, i should use a wide as possible aperture in low light, dial the ISO number up but expect noise, and use a slower than usual shutter speed. Does anyone have any tips? Granted i was shooting in manual mode, and i read yesterday i should be using a rough rule of 'shutter mode for moving objects, aperture mode for stationary objects' - so that may have helped me.
Is the darkness element down to something i'm doing, or is it that the aperture of the lenses above isnt a low enough F number to allow sufficient light in at a high shutter speed?
Thanks in advance - all the things / videos ive watched from references on here are really helping.
Cheers,
Sam
As shot
After edit
Cheers,
Sam
