Shop refusing to comply with SOGA
Just remember that although Sony have provided a replacement, any future beef you have under SOGA lies safely with Sainsburys.
The product is warranted under SOGA for at least 3 years with the retailer not the manufacture. Sony will lose interest after the standard 1yr warranty product lapses. Just make sure you keep your receipt or proof of purchase in a safe place and do not be tempted to void the warranty by breaking the seals of the PS3.
This advice is obviously not restricted to Sainsburys but to any retailer who you may have purchased a PS3 from.
I know this intimately from recent personal experience.
The act states up to 5 or 6 years, depending on the product
I would argue that 3 years is on the short side of a lifespan for a console
That is the limitation period in which to make a claim for damages (ir repair , replacement) not a warranty as such
Not really, shop can simply give a new console to replace the broken one
There is absolutely zero legislative requirement for them to do this.
Why is ryptworld so different from the real world?
Many shops will simply give a new console but they are under no obligation to do this and can send it away for repair if they wish.
or show that the product has not lasted a reasonable amount of time
ie a £5k tv dying after 2 yrs would be unreasonable
That is the same thing and requires you to show the fault and not caused by ware and tear, misuse or anything else.
Good luck with quoting that in a shop! I don't see a huge problem here to be fair I would much rather deal with Sony than a place that's a supermarket.
I may have ballsed up that reply
I meant EU Directive 1999/44/EC that states minimum of 2 years
Directive, not law ;)
edit: UK law states that you have a year, however if you can prove there is a fault before 6 months you have a 6 year window to try and get a replacement/repair
Pretty sure that's never been incorporated into UK law.
It has to be.
Member States shall bring into force the laws, regulations and administrative provisions necessary to comply with this Directive not later than 1 January 2002.
The point is, a fault has to appear within 2 years under EU law and 6 years under UK law ... so if an item breaks within that period, and the fault can be assumed to be due to a defect in the product (such as the case here with the PS3 cooling) then the seller has to rectify the situation
It has to be.
Its 1 year in the UK
