Short ATX cable
1 Aug 2003
Cheshire
What is the go to product for very short ATX cables? I'd like a mobo power cable ~100mm long, but the shortest off the shelf item I see is ~250.
Ideally, as flexible as possible too. Its for a Seasonic PSU.
You are probably looking at getting a ATX custom cable made up from somewhere like Pexon although unless you can choose different sleeving the MDPC they use might not be as flexible as you require it. Might be worth enquiring though.
I presume it's a modular psu? As above really, you would have to get one custom made. There is a alternative and that would be to make your own or cut your current cable down and fit new pins and a plug to it. Pins and plugs are readily available and it's easy enough to do. Just make sure you don't mix up the pin outs or something will go horribly wrong.
The motherboard side of an ATX cable should be standardised, but the PSU side varies significantly, so yes, custom would be they way to go.
Just curious, what companies are recommended in the UK for this?
