Hi,
this is a story why you should get enough sleep before messing with hardware.
PSU: Kolink Continuum 1200 W Platinium 80+
I disassembled my PC for cleaning, after putting it back I forgot to connect 10 pin to the PSU. (as shown in the picture).
In other words, 18 pin alone was connected to the PSU, and 20+4 pins to the motherboard. I haven't noticed that and obviously PC didn't turn on.
I began inspecting hardware and I've done the paper clip test putting it in 4th pin and 5th pin. PSU made short cracking noise. I've noticed my mistake and put 10 pin cable back again.
Computer works normally, fans are spinning, everything looks fine except that PSU sometimes makes short cracking noise when I flip off the switch. It doesn't make that sound when I turn it on. I can't smell smoke or see any sparks.
Should I be concerned? If yes, what should I do next?
