Mini-ITX SATA data cables available seem to start at 15cm which is fine if thats the distance you need it to span, but I am looking for ( and have found ) cables that are 10cm and 7cm which is just what I need. Seems none in this country, which given the rising popularity of SFF seems like suppliers are slow on the uptake.
Correction, I did find some advertised on specialist HTPC sites but silly prices and hit and miss ( usually miss) availability.
I got mine for under £2 each, only drawback is they are plain straights where I wold have preferred one end right angles and latched. But they will still do the job, and I don`t intend to have a clumsy gerbil roaming the innards of the build so can live without the latching.#Had to go to Hong Kong in the end for them so ordered two sets. Plus lots of other goody bits for ITX
