- 22 Jan 2024
- England
Just built a new PC and am worrying about the performance of my I9 14900k. Should I be worried about this?
During the 3D Mark CPU Profile Test, the Max Thread part ramps up my CPU temperature to a maximum of 88 degrees. This seems very good, however, I've found that just the sheer act of launching the 3D Mark application causes "P-core 2" spikes to 98 degrees very briefly (for 1 reading) and shows up "yes" that it's throttling. Occasionally some of the other P-cores throttle too during this process. I am using HWinfo for monitoring.
I am just confused, is this normal? Why does a core throttle when loading up 3D mark, but yet when I'm running the actual tests it only reaches 88 degrees maximum.
More info:
- Idle temps are 28 degrees.
- CPU is overclocked by: Multicore enhancement (Auto - let bios optimize). And Intel adaptive boost technology enabled. XMP also enabled.
(POSTED MORE INFO AND IMAGES IN MY COMMENT BELOW)
More info:
