Should I be worried?
4 Apr 2012
England
I built my pc just over a month ago now, and a week ago I decided to OC my Sapphire 7850 card. I get good temperatures and no graphical glitches, but sometimes (happened four/five times now in the past week) a loud squealing noise comes from the GPU? I have the Core at 1050MHz and the Memory at 1350MHz. I also have set the power slider to +25% (I am using MSI Afterburner.)
I am also running a i5 3570k (Not OC'd) and 4GB 1600Mhz RAM on a Corsair 500w PSU. I have read it could be something to do with the coils or something like that?
Thank you.
Apparently having a capacitor on the PCIE connectors to the graphics card helps reduce the coil whine. This is taken from the Silverstone website. Some Silverstone PSU's have this feature.
http://www.silverstonetek.com/product.php?pid=318&area=en
Click the above link and scroll down to number 7.
To reduce electrical whine/buzz associated with high performance graphics card’s dynamic loading changes, 2200uF capacitors are attached to PCI-E connectors. This design also helps to maintain better voltage stability and improve ripple & noise performance.
Not sure of the validity of this as I have a Corsair PSU. Not everyone gets coil whine (I don't) and I think it may be down to the quality of the output in the first place. Putting a capacitor like Silverstone do is a bit like sticking a plaster on it, but hey if it works...
