As above really. I'm looking at a fan controller that will control 4 fans and a couple come fitted with temperature sensors/readouts. However, I am not sure if you can program the likes of the Zalman MFC2, or Scythe Kaze Master, to actually change the fan speed according to the temperatures, and, if not, then I would prefer to monitor my own temps and manage the fan speeds manually.
It also seems to me that any sensors placed inside the case would be less accurate than temps from the likes of Speedfan, Coretemp, etc. as it will not be possible to place sensors directly on to the chips (as far as I can see).
Any experiences or thoughts (on this subject
) would be welcome.
