- 18 Mar 2011
- East London.
Currently own a Seasonic Platinum 1000w.
Im in the process of downgrading my rig from EATX to MATX.
CPU i will be running is an overclocked 2700k@ 4.7
My GPU for now is a stock HD7950 twin frozr. This GPU will probably get replaced when the new gen of cards finally reach us. will eventually look to OC the new card.
I will always run one card, not into sli/xfire.
Other things i run are about 7 fans, 1 d5 pump and a fan controller and some LED strips.
Im thinking that i probably dont need all that 1000w potential, so do i sell the seasonic and get something smaller?, if yes, then what sort of wattage im a looking at? Or should i just keep what i have even though it is overkill.
Thanks
Thanks
