Hi
I've posted on this before, but I'm still struggling and read mixed things about the effectiveness of high- end routers for wifi on the 'net...
I am using a BT HH5 at the moment, and the wifi is frankly a bit of a nightmare.
As you can see from my home's floor plan (ground floor in case it matters), it's not a particularly big flat (London living, y0!), but it is quite long (14m) and narrow (5m), with brick walls in between each room, meaning the wifi signal does not penetrate well throughout the house. Currently I have:
This works 'OK' but I get very poor speeds in some parts of the house and dropouts, etc. quite often. Radio on Sonos is almost unusable, as the homeplugs seem to experience 'micro dropouts'. The wiring in the house is pretty old (There are no proper circuit breakers or anything), so I expect the homeplugs are suffering as a result.
I have tried moving the HH5 to where the bend in the hall is (outside the bedrooms) but I struggle to get a good signal when moving away from the HH where there are walls in the way.
Note: I cannot just run LAN cables around the place, as I have stripped wooden floors throughout, and I don't want to lift/ damage boards. Most of them are well nailed down.
Also I don't want to use repeaters/ boosters, as they halve effective bandwidth.
My plan is to try putting a new high- powered router up on a high shelf in Bedroom 2 (Study) and running cables under the floor to the telephone socket which is in the hall. I can do this as the cable is narrow enough to push between the floor boards, and there are a couple of liftable ones, luckily. I am hoping this might improve things, and will allow me to wire my server to the router directly. Do you think this would improve things significantly? Is there anything else that could be done?
The only other option I see is to drill through the external walls and cable down the side return, (I can bury the cable under the gravel so it would look OK) and popping a LAN point into each room. This is going to be messy and expensive though, and will still require multiple access points.
Thanks!
- HH5 in the lounge
- BT Homeplug wifi plugs in:
- Bedroom 1
- Bedroom 2 (Study)
- Kitchen
Thanks!
