Should i get Pro Evo 7 ??
12 Feb 2007
i have an xbox 360 and i have fifa 08 on it. Enjoyed it loads. But i saw Pro evo 7 for £9.99 on play for the PC. Should i get it ???
i have a few questions:
1. Same graphics as the next gen consoles ???
2. is it better than fifa 08
3. is it better than the last pro evo
4. any one using the xbox 360 controler ?
5. can i play it on high settings with these specs:
X1950 pro
2 gig ram
e6600 2.4ghz
pes2008 is good,
just make sure you get kitserver for it, so you can run with full detail and at the correct resolution.
Canna believe Konami released it in the state its in though
If you like single player version of this game, then I would get it for 9.99. I got it as I play with my brother onilne but you can only play 1v1 now as opposed to the up to 4v4 before.
Personally I was very let down with this years and as a result wont be buying the next one unless the previews state that its back to its brilliance.
