Man of Honour
- 17 Oct 2002
- Retired Don
Hi guys,
We've got a utility room off the kitchen. The door going from the kitchen into it is a proper outside door. The utility room was just built many years ago as a lean to, but has a sink in it, plus the washing machine, freezer etc etc
There is no heating in the utility room, and it is essentially nearly as cold as it is outside.
I was considering putting an oil filled radiator in there and leaving it on 24/7 but on a low setting with the thermostat on it quite low, just to keep the temperature in there above freezing.
I'm concerned with the tap and washing machine out there, when it is really really cold the pipes may freeze up overnight.
What are your thoughts? Any cheaper way people can think to heat it?
Cheers
Cheers
