Should i move my fans?
7 Oct 2009
On the Antec P183 it came with two 120mm, one at the top of the case and one in the usual exhaust position. I thought it was a little weird that there were two exhausts and no intake? Should i move one of them to the bottom front so i have an intake and an exhaust or is there a reason why this hasn't already been done? If yes then which one should i move? Thanks.
you can if you want but i have a antec p183 and the cooling is very good with the fans in the top and rear of the case if you want to you can add some fans in the front;)
