Should I or shouldn't I?
15 Feb 2011
North Yorkshire
Do I really need a fan controller? I have a 2500k at 4.6ghz and 2x480 sli in an antec 1200. I put new sharkoon 120mm fans in the front and the CPU is water cooled. Would the fan control be an advantage or am I wasting money?
Ok thanks. Well what other upgrade can I do? Full spec is Asus P8P67 pro with 2500k @ 4.6ghz water cooled with H50 corsair 1600ram 2x480 gtx sli 950w corsair psu sharkoon 120mm fans all round in a antec1200 case! Any thoughts?
SSD, Blueray writer, new/bigger TFT
The bios can probably clock down the voltage to chassis 1 & 2 fans they don't have to be PWM fans see if there's a fan control in hardware monitor in the bios.As you'll probably find you wont gain any temp setting the 2 fans to 7 volts.
Two case fans? There are five moving air around in my case and one on the H50 water-cooling rad.
