should i overclock my pc
17 Nov 2008
should i overclock my pc im only using it for games . if so how can it be done .thank you
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included
SuperFlower Golden Silent 500W Fanless "80 Plus Platinum" Power Supply - Black
Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW)
Gigabyte H87-HD3 Intel H87 (Socket 1150) DDR3 ATX Motherboard
Cooler Master Silencio 550 Silent Tower Case - Black
TeamGroup Vulcan ORANGE 16GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01)
Raijintek Aidos Direct Contact CPU Cooler... thanks
Would be criminal not to overclock it
Hopefully another ghz on the CPU if your lucky and maybe 10-20% on the gpu
Short answer: yes
you can do at least 4.2Ghz in all cores with this cooler, probably 4.4/4.5 but you need to check voltages and temperatures.
Ban if you don't!! :D:p:D
No point in buying a K series cpu if you don't clock it.
On second thought's, I just noticed you have a H87 motherboard. What overclocking options do you have in the bios? I can overclock my 4670K to at least 4.4ghz on my wifes Gigabyte B85M-D3H but someone on another forum had no luck.
Just downloaded the manual for your board and it does have a decent range of overclocking options. That's not to say it will definitely work though. One thing I did notice though was that the manual says it only supports 1333/1600mhz memory. Usually it would have faster speeds after it that can be used by overclocking so it would look like 1333/1600/1866(OC)/2133(OC)/2400(OC). I don't know for sure that your 2400mhz ram will run at it's full speed.
