Got vista today and put in my X-Fi Xtreme Audio card. Im using x64 and the drivers are sooooo shoddy. I have no console or any way of enabling features and changing speaker settings
Should i use my sound card that came with my P5N32-E Sli mobo?
PhillyDee said:Throw it away. Ive just pulled mine out. Now using onboard sound on my DS3 and its better than the X-FI will ever be.
PhillyDee said:More a case of the Onboard has the drivers, the utilities, the advanced functions, doesnt crash my games randomly, the support. And creative have . . slightly better sound, a card whose drivers crash my games, crappy EAX support, disastrous drivers, no advanced options (Not even a mic boost) and customer service which doesnt even live up to its name.
Psypher5 said:You need your ears cleaned then.
Psypher5 said:if your card really is messed up, (heck, mine was i wont argue it aint possible) theres some fixes to do with tinfoil and EMI ness, or shout at creative and they will change it.
PhillyDee said:They basically said Tough Titties. Dont get me wrong, it was fine under XP 32-bit, vista 64-bit its just substandard. Anyway, i dont like them because of this debarcle (sp?) and nothing is really going to change this. There are a lot of disgruntled people if you look in creatives forums about the Vista support.
Never had any problems with drivers under XP, it just suffers under vista.
Edit: And yes, I do need my ears cleaned . . . . .Im half deaf at the best of times. Bloody engineering.
