Should i see an improvementin speed?
29 Sep 2006
West Yorks
I have just cancelled my service with ADSL24 and gone with BE, with them being ADSL2+ will that mean i get a better speed?
They said to expect 3mb, but i hear a lot of people saying when BE quote a speed its nearly double.
I am nearly 4km form the exhange and currently get 2.8mb.
You are still quite some distance from the Exchange so 3mb/s is probably the best your gonna get for now.
A good website to check your speed is www.speedtest.net.
I took up to 8mb/s with BT and the distance between us and the Exchange is approx 1km and we get 7.2mb/s.
speedtest.net will only give you a (bad) measure of what you get just now. What you should do is get attenuation/SNR margin from your modem and stick it into the guesstimator in the sticky.
I know all that, was just wondering if being on ADSL2+ would give me a better speed or not.
Thanks all the same.
Sorry i rushed it, i have now read it.
Your maximum line connection speed using an ADSL (up to 8Mbps) service is: 3948Kbps
If you are on a Max product, that uses the IP Profile system (sometimes called BRAS Data Rate) if you maintain the above line speed for 3 days or more your IP Profile would be set to: 3Mbps
If your service provider uses ADSL2+ the maximum line speed likely is: 5028Kbps
With ADSL2+ the maximum IP throughput is likely to be around: 4450Kbps
The range of ADSL speeds expected at this attenuation are 3100Kbps to 4400Kbps
Your ADSL2+ speeds are likely to be in the range 3300Kbps to 5600Kbps.
