Hi,
I managed to run a overclock of 4.1GHz @ 1.280v for a full OCCT Large 6 hour test. These are the results:
However when I try for 4.2GHz @ 1.280v it got about 1 hour in then said one of my cores went over the maximum value.
Should I keep 4.1GHz and try reducing the volts to get a sweet spot or should I go back onto 4.2GHz and try lowering the volt to get a safer temperature? (I just cleaned out and re-applyed thermal paste to CPU so it could be it needs time to break in first)
Thanks
Thanks
