- 27 Jan 2012
- The king of the north!
Hello fellow overclockers,
I recently upgraded my system and got myself a Gigabyte gaming 5 motherboard along with a 4690k and 8GB 1600mhz ram. Cooling is a H110 with gelid gc compound ( i love this stuff ) im also open to delidding my cpu if you think it would be worth it but for now it's all stock paste under the ihs.
I have overclocked in the past about five or six machines. But never on haswel.
I have my voltage set at 1.22 in the bios and multiplier is 46. In CPUID the voltage goes up to 1.248 at the max this is rock solid stable 24/7
Hyperthreading is still turned on and everything else has actually been left to auto im sure someone will shout at me for that
Now for temperatures
In gaming i chose Arma 3 for this test as it's quite the cpu hog after a 6 hour run with a 10 min gap between for a server restart i never saw my temps above 38
for a synthetic test i chose Aida64 as i have been seeing quite a bit of negativity surrounding prime95 and the life of cpus.
below are the max temperatures of the different core temperatures
10 minutes Core 0 49c/ Core 1 51c/ Core 2 50c/ Core 3 47c
20 minutes Core 0 50c/ Core 1 52c/ Core 2 50c/ Core 3 47c
30 minutes Core 0 50c/ Core 1 52c/ Core 2 51c/ Core 3 48c
40 minutes Core 0 50c/ Core 1 52c/ Core 2 51c/ Core 3 48c
50 minutes Core 0 50c/ Core 1 52c/ Core 2 51c/ Core 3 48c
60 minutes Core 0 50c/ Core 1 52c/ Core 2 51c/ Core 3 48c
What do you guy's think should i try to push this a little further?
and how would you suggest
Thanks
Harry
! Now for temperatures
Thanks
Harry
