Getting slightly back into gaming and with sales/black friday about it might be a good opportunity.
I've been thinking of a new GPU on/off for some time as usually I miss a generation but this 670gtx has lasted me quite some time. Thought i'd get some recommendations for other cards, I stick with Nvidia these days. I thought i'd check incase a GPU upgrade is pointless and bottlenecked by this spec?
Currently i'm using 1080p but looking to go to 1440 in the future, although wouldn't be for a year I would guess.
Edit: update... Still not got around to it! Wondering if it's wise to wait now as prices may potentially drop within next few months?
My current spec:
Gigabyte Z97X-SLI
i5 4690k
8gb RAM (2x4GB) DDR3 PC3-21300C11 2666MHz
670gtx 2gb
Got 2x256gb SSDs and 3x1TB HDD's.
Danke Shoen
My current spec:
Gigabyte Z97X-SLI
i5 4690k
670gtx 2gb
Danke Shoen
If you are only wanting 1080p then it's not really worth getting a more expensive card.
, but no matter how good I think it is personally, can't see past the £380 MSI Quicksilver that is £100 cheaper than the current Amp Extreme price
