Should I upgrade my CPU cooler?
19 Aug 2011
Leicester, UK
Hey,
Just after a little advice from all you experts on here. I'm currently using a H50 cooler on my processor(i3 750 @4.3ghz), but as of Wednesday I will have a i5 2500k, was just wandering if anyone thinks it'd be wise to upgrade my cooler?
When I was running my i5 760 i was hitting temps of around 72-74 max @ 3.7ghz using maximum setting 3 passes using IBT.
If you do recommend an upgrade can you recommend one? I have no preference to air or water, although I dont have money/time to set up a custom water cooled system. Just bought the akasa vemon toxic case so case cooling shouldnt be a problem.
Thanks Shadow
Current cooler should be fine, so no need to change it, if you want slightly better performance and noise, you could opt to change the stock fan on it, for 2 quieter ones in push/pull.
