should i upgrade.?
17 Nov 2008
i like playing new games should i upgrade my graphics cards or are they good for another year cheers
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express i have two running crossfire
SuperFlower Golden Silent 500W Fanless "80 Plus Platinum" Power Supply - Black
Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW)
Gigabyte H87-HD3 Intel H87 (Socket 1150) DDR3 ATX Motherboard
Cooler Master Silencio 550 Silent Tower Case - Black
TeamGroup Vulcan ORANGE 16GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01)
Raijintek Aidos Direct Contact CPU Cooler... thanks
xfire 2gb 270x is probably not a great idea to be honest. I would be thinking about getting one decent GPU with more Vram
What would you like to spend?
Upgrade only when games become semi unplayable. I've only just upgraded from a ATI 6950 2GB.
And in fact I could have still used that. Witcher 3 was still very playable at medium settings at 1900x1200. Only in Doom 4 was it a slide show. Every other game still played fine at that res. Tomb Raider etc.
As above depends really what settings you're happy with.
You won't be maxing out the latest and greatest games with a 270x unfortunately.
Something like the RX480 is affordable and will also allow you to play most games on high settings at least.
just pick up a new GPU within your affordable budget, the time to buy new hardware is now. You will eventually left behind in the end anyway.. such is the industry.
Limited to the max turbo you mean? Or does it actually have some proper overclocking options such as vcore etc? I know my wifes B85M-D3H can overclock my 4670k but I just haven't heard of anything but a G3258 being overclocked in a H87 board and even then only a couple of times.
***Edit*** Actually a quick Google shows that 4.4Ghz may be achieveable on this board but you have to be careful of the temps. I stand corrected. :o
You don't need to overclock your CPU to be honest, it's perfectly fast and in a lot of games will easily outperform an overclocked i5 for instance (BF1 is a good example).
If you only upgrade once every 5 years, I agree you might as well just get a GTX1070 now.
The 270's will net you back £130-150 or so.
