Should I use Sysprep?
11 Aug 2003
Taunton, Somerset
My old Athlon XP is slowing down and eventually I think the motherboard will give up completely.
Therefore I have bought a new Athlon 64 and a motherboard. The old system was set up with raid 1 and so is the new.
Rather than install a fresh copy of Windows XP on the C partition do you think using sysprep on the current installation will overcome the trouble I will have with the drivers?
Any ideas on what I can do to avoid a fresh install
