Ok so I bought this in 2011
https://www.overclockers.co.uk/showproduct.php?prodid=HS-005-AN
I have it on pretty much 24/7.
Last night it was making a really loud grinding noise so I shut the PC off and pulled the kettle lead.
Woke up this morning and checked for any leaks etc, no leaks.
Turned the PC back on and again the same grinding noise was apparent, googled it and I found various new owners had the same issue but it was down to air being trapped, although that wasn't concluded as the definite cause.
Tilted my pc this way and that to see if it made a difference, no difference. Left it running for 5 min and the grinding disappeared and it is now as quiet as it has ever been.
Should I be worried?
