Should it be so hot?
11 Nov 2009
Edinburgh
Because I messed up with the case size rather than wait for the replacement due end of week I though I would get get everything set up, BIOS flashed, Windows installed, games and programs ready.
But I was having shut downs and after a thread elsewhere it was suggested that the cooler Corsair H60 was seated correctly and it did look as though this might be the case but it took one or two adjustments as I find with AMD that I am unsure how far to tighten the screws.
After one shutdown I touched the pipes and was surprising how hot at least one pipe and wondered if an upgraded AIO might be the way to go with the 5800x?
I'm assuming the pump is plugged in (you've got that exposed sata cable over the pump though) and running etc because I made an oops when installing my rig and forgot to plug mine in which had it thermal shut down on me.
As for the hot pipe...105w cpu on a 120mm radiator.... yeah it's going to get hot. My 5950x (also 105w) will hit 70ish degrees (hwinfo) on a 360mm rad, so I'd hate to think what it's like on a 120mm...
I found my rooms got a whole lot more untidy after partnering up :D.
The H60 should be fine in my opinion although it wouldnt hurt to get something with a larger rad. Are you sure 850 is enough for your gpu?
All my research and advice here says yes as I have only the mobo, GPU and pump powered direst from PSU
I did not notice the sata plug round the pipes as pointed out by @Isg1r and have now connected that, I really think I am finally getting to old for this stuff. :D
I was thinking of the Arctic liquid freezer 2
if your aio pipes are hot either the pump is dead or not plugged in, check all cables and make sure they are all plugged in and try again.
the 850w should be ok to power the 4080 you have, its the minimum recommended for that card.
Thanks all, stupidly the pump was not plugged in. Have thoroughly stressed tested today and all running sweet.
I have had some great advice to my rather simple issues over the past week or so, thanks all for your patience and help.
Surprised nobody noticed the SATA3 plug sat on top of it doing nothing ! :)
One temps are you getting now ? I wouldnt like to use a single rad on a 5800x at least a double for decent temps.
