should this fit or not
5 Feb 2010
parts just arrived, trial fitting things
looks like I can not fit my memory and fan cooler
Can I mount the cooler the other way round and get the fan to suck ?
do i need the fan?
cound i just mount the cpu fan on the rear of the case?
this is the spec
gigabyte p55-us3l
i5 750
gelid tranquillo cooler
patriot sector5 viper II pc3 12800
NZXT Gamma Black Mid Tower Case
You could turn the whole heatsink round, and then turn the fan round too.
I have done similar. Can you not also mount it 90 degrees out, your case has a top fan to remove the heat.
Its too wide to mount at 90 degrees, it would foul the memory with with the fins.
If turned a round and the fan reversed, should I fit some top fans too.
Case fan is 120mm mounted at the bottom of the front of the case.
I would remove the rear fan
You can of course experiment! As long as the heatsink is attatched it should not overheat.
Use speedfan, try it with the rear fan + cpu fan. Then try it without the rear fan, then with rear but without cpu fan. You could even try adding a top fan into the mix and see what happens! I would add a top fan to the middle grill, but probably not the one at the back. I would be tempted to blank off the rear fan hole on the top to see if it increases airflow. (Try it with a book on top first, then use some coloured acrylic).
Remember to stress the CPU when checking temps. Idle means nothing in this game :D
