- 22 May 2011
- Perthshire, Scotland
It is often advised that before you start building your new system inside your shiny new computer case, that you put together the most important parts in a test build outside the case to see if it POSTs.
So that means
PSU
MOBO
CPU
CPU Cooler
Memory
Graphics card
Monitor
There are a few of advantages to doing this:
1) No need to disassemble the case if there is a problem.
2) If you have an aftermarket cooler, then you can easily fit the backplate before installing it in the case.
3) The mobo is all set up before when you install into the case, may be a little less fiddly.
My Question is about the CPU cooler. I was planning fitting something like a Corsair H80 to a i7-2600K on an Asrock Z68 extreme board. Should I fit the cooler on the test build. Case probably CoolerMaster HAF X or Corsair Obsidian 800D.
To me, at the moment, fitting the cooler appears to be a one time job, especially as you have to add the thermal paste. So, fitting it when the mobo is outside the case makes sense. However, with something like the Corsair Hxx, then you also have to fit the radiator and the fans to the case which may make things a little more awkward. I think the Hxx comes with thermal paste already applied.
For those of you with a Corsair Hxx cooler, did you attach it to the cpu/mobo whilst inside the case, or did you do it on a test build outside the case?
So that means
PSU
MOBO
CPU
CPU Cooler
Memory
Graphics card
Monitor
