Show me you 'Fractal Design Arc Mini'
That enermax fan is a bitfenix fan now.
I never used the one in there, When I modded the front to accept 2 140mm fans I couldnt use the fan controller in the bottom drive bay as part of it contacted the top of the fan, so The fan controller went in the top bay and I removed the optical drive as it was barely used. Haven't missed it tbh. If i need to its a 10 second job to whack a sata cable into the motherboard and plug a cable into the psu.
Yea will easily take a h100i and will do push pull if your ram is low profile
Yup nice thing with the arc mini is the top mounting point is offset rather than in the center of the case, so the radiator and fans clear you memory slots very nicely.
yea certainly helped the gpu temps, its an overclocked 7970 so it puts out some amount of heat!
did you want to know anything else about the case?
No thanks mate, I appreciate the images you provided me. I'm going to order one tomorrow :)
Do you have a fan on the bottom of your PSU?
Cheers
Here is my system right now:
I7-3770K + 8Gb 1600 Ripjaws x + Noctua NH-C14 + Sapphire VaporX 7950 HD
I had a few troubles with the cooler and was forcde to put the graphics card in the 2nd PCIE since there was contact between both in the first slot, and now the card does not have much space to breathe, and i also lost PCIE 3.0 since the 2nd slot is only 2.0.
its a 12v led light strip you order it in set lengths its sticky backed , choose the colour you need then solder a 3.5" size or similar hard drive power connector on then plug it in your pc.
costs about £10 for what i did.
