Show us your ide temps
17 Dec 2004
Room temp 13c and playing music videos, so not completely idel
Room Temp about 17C (going by gauge on wall).
4970K @ 5GHZ (sitting at 800mhz @ 0.790v Idle) + Noctua D15S Cooler with stock NF-A15 fan.
3090 (idle/Fans Off)
NZXT Phantom 630 Case with all Noctua Chromax Fans:
1x Front Intake and 1x Side Panel Intake and 1x Top Exhaust all 200mm.
2x Bottom Intakes and 1x Rear Exhaust all 140mm.
room temp mid 20s.
5800x pbo enabled
6800xt idle
cpu watercooled connected to 2 360mm rads with 3 fans. Incomplete setup as build not finished. Waiting on GPU waterblock
When i game, CPU rises to low 50s while GPU jumps to mid 80s.
Ambient room temperature ~27C
CPU: 4930k (0.85v 1.2Ghz idle, 1.22v 4.2Ghz full)
Cooler: Noctua U12A
GPU: RX580 with Zero Fan option on (deshrouded and Noctua A12x25s strapped on instead when in use)
CPU Idle temp: ~38C
CPU Max temp (Heatsoaked Prime testing): ~75C
Gaming CPU temps are often much lower, mid 50s to 60s at most for most modern games and even lower than that for older titles.
