- 12 Jan 2003
- Watford
Hi All
As you can see from the pic the shower head has broken.
I think I can find a replacement online, but just wondering if the pipe/nut size that connects it to the main part of the tap are all the same size, or do I need to measure it in a particular way ?
https://imgur.com/a/NFFx6cW
Do I just used some pliers and a rag to protect the surface finish , when installing ?
Thanks
Mehul
Thanks
Mehul
